06 silvy low on oil but not leaking
Old Jan 10, 2008 | 7:22 PM
Rubedog302's Avatar
Default 06 silvy low on oil but not leaking
i have a 2006 silverado with 51,000 miles.i change the oil regularly.. but today it said check oil level ..so i did..and it was really really low..but i dont' burn black smoke from the exhaust and i am not leaking antything underneath where the oil pan is...although in idle..a little smoke comes up..but light gray almost white..like when its cold and you breathe..that color..so..any help or suggestions would be awesome
Old Jan 10, 2008 | 8:15 PM
ZX1100F1's Avatar
Default RE: 06 silvy low on oil but not leaking
Did it just start doing this?
How much oil is it consuming? Such as 1qt every 500 miles or 1,000 miles or 2,000 miles etc?
Do you notice any gray smoke (not steam) when you first start it after it has sat for several hours?
Old Jan 10, 2008 | 8:47 PM
Soah's Avatar
Oil pressure Switch could be defective., This will cause more then normail oil consumption
Old Jan 10, 2008 | 8:59 PM
Rubedog302's Avatar
as far as the consumption..i couldn't tell you..i would have to start keeping track..i started using synthetic since the first oil change when i bought it brand new. dont know if that would make a difference..but sometimes smoke does come out the exhaust when i first start it up after it has sat...but light smoke..not dark..and not alot..if it is the switch..is that something i can change or have to take in to the dealer
Old Jan 11, 2008 | 10:25 AM
ZX1100F1's Avatar
A faulty oil pressure switch will not cause oil consumption, if it is not sealed it may cause a leak but you said that you don't have a leak.
My best guess is that there were some 5.3L engines that were assembled with faulty valve stems, if this is the case both cylider heads will need to be replaced.
Have the dealer reference GM Document ID #1961494 for more information, if your engine is effected by this then there is a good chance that GM will cover the repairs as a good will gesture even though you are out of warranty, if you have an extended warranty then it should cover the repairs provided the oil consumption is beyond acceptabe levels which are no more then 1qt in 2,000 miles.
Synthetic oil has nothing to do with this.
Old Jan 11, 2008 | 11:11 AM
Soah's Avatar
GM repair Manual says it will. Course it could be wrong. I don't know for sure my pig just leaks never had an issue with the switch.
Old Jan 11, 2008 | 8:28 PM
Rubedog302's Avatar
thanks for the info.much appreciated..i will add some oil..but i think i will have chevy look at it..and see..i got the extended warranty..just incase something did happen..soo..i hope its nothing major
cdcpedroso
Feb 11, 2022 11:18 AM
Jeepking88
May 19, 2014 3:11 AM
DeeZ
Apr 24, 2009 11:02 PM
99NBSSilverado
Mar 18, 2009 3:52 PM
larry_chip
Apr 24, 2007 11:46 AM
