Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, K2XX Headlight Legal Requirements
Important information to help you understand your Silverado.
07 Silverado DLR headlights
Just got 07 2500HD. Need to remove/overide the switch thay allows DRLto be turned off on US model. Can a Canadian MODELheadlight switch be used or is this done by program? I have had 9 new Chevy truckssince 77 and this is the best. please advise what can be done .Thanks
RE: 07 Silverado DLR headlights
You need to have the BCM reprogrammed. But unless you are with the FBI,CIA, Local PD etc, then you're SOL. In order to get the new software for the BCM, technicians must call GM to get them to release it. Unless you meet some requirements, they won't release it.
Requests for DRL/auto headlamp disconnects must be made by appropriate agencies. The vehicle in question must be owned by a law enforcement agency, military agency or security company. (City/State, Sheriff, FBI, CIA, DEA, Emergency Vehicles.Etc.) It is recommended the dealership obtain a letter on the agencies letterhead requesting the DRLS/auto headlamps be disabled. The letter should contain the specific vehicle identification number which will be disabled, and a statement which reads, "the DRL/auto headlamp system will be made fully operational prior to disposal/sale of the vehicle." the letter should be kept in the vehicle service file at the dealership.
NOIwant to make them so they can not be turned off. Us models allow this while Canadain are always on.I need them always on.
Heres the deal. In Canada we are required to have DRL that CAN NOTbe turned off. I need to pass a one time federal inspection of a truck made in Pontiac Michigan. After that it does not matter. I will run with them on, but regulations say they must not be able to be turned off or deactvated. How do I pass the inspection? CanI just put on anorth of 49 switch , CAN THE ORIGINAL SWITCH BE REPROGRAMED TO ignore the turn off function? Thanks
sounds like a ligetament excuse to get it programmed, but if nothing else, you can just hardwire the DRLs in. or bring it to a local auto electronics place that puts in security or remote starting systems and they should be able to help ya out
Attention CANADIANS Before you go for the federal inspection cut the green wire in location # 3 in the connection blockto the head lamp switch. It comes out with no tools. This will leave the DRL on with no ability to turn them off while in gear.. Reconnect after you leave Canadian Tire or leave it. Canadain Tire will not pass the vehicle if rhe DRL can be switched off.
warthogcrewchief
February 20th, 2015 6:12 PM
David_lee1993
November 1st, 2012 11:06 PM
chvy_boi
February 28th, 2009 11:05 AM
gerkendave
November 3rd, 2008 11:36 AM
slbarnesjr
July 25th, 2007 9:52 AM
