Old Aug 10, 2015, 1:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
07 Silverado DLR headlights
Old Apr 25, 2008 | 11:46 PM
sybra's Avatar
Default 07 Silverado DLR headlights
Just got 07 2500HD. Need to remove/overide the switch thay allows DRLto be turned off on US model. Can a Canadian MODELheadlight switch be used or is this done by program? I have had 9 new Chevy truckssince 77 and this is the best. please advise what can be done .Thanks
Old Apr 26, 2008 | 8:26 AM
EvansBlue's Avatar
Default RE: 07 Silverado DLR headlights
Are you looking to disable the DRLs?
Old Apr 26, 2008 | 8:42 AM
shawnvw's Avatar
Banned
You need to have the BCM reprogrammed. But unless you are with the FBI,CIA, Local PD etc, then you're SOL. In order to get the new software for the BCM, technicians must call GM to get them to release it. Unless you meet some requirements, they won't release it.
Requests for DRL/auto headlamp disconnects must be made by appropriate agencies. The vehicle in question must be owned by a law enforcement agency, military agency or security company. (City/State, Sheriff, FBI, CIA, DEA, Emergency Vehicles.Etc.) It is recommended the dealership obtain a letter on the agencies letterhead requesting the DRLS/auto headlamps be disabled. The letter should contain the specific vehicle identification number which will be disabled, and a statement which reads, "the DRL/auto headlamp system will be made fully operational prior to disposal/sale of the vehicle." the letter should be kept in the vehicle service file at the dealership.
Old Apr 26, 2008 | 11:01 AM
sybra's Avatar
NOIwant to make them so they can not be turned off. Us models allow this while Canadain are always on.I need them always on.
Old Apr 26, 2008 | 11:44 AM
northey87's Avatar
Welcome to the forum!!! Then just leave the switch on.Are you wanting to have them on while your headlights are on?
Old Apr 27, 2008 | 12:16 AM
sybra's Avatar
Heres the deal. In Canada we are required to have DRL that CAN NOTbe turned off. I need to pass a one time federal inspection of a truck made in Pontiac Michigan. After that it does not matter. I will run with them on, but regulations say they must not be able to be turned off or deactvated. How do I pass the inspection? CanI just put on anorth of 49 switch , CAN THE ORIGINAL SWITCH BE REPROGRAMED TO ignore the turn off function? Thanks
Old Apr 27, 2008 | 2:18 AM
cdusthockey's Avatar
sounds like a ligetament excuse to get it programmed, but if nothing else, you can just hardwire the DRLs in. or bring it to a local auto electronics place that puts in security or remote starting systems and they should be able to help ya out
Old Apr 27, 2008 | 6:59 PM
shawnvw's Avatar
Banned
I'm sure the dealer can reprogram the BCM to get them working
Old May 11, 2008 | 3:30 PM
sybra's Avatar
Attention CANADIANS Before you go for the federal inspection cut the green wire in location # 3 in the connection blockto the head lamp switch. It comes out with no tools. This will leave the DRL on with no ability to turn them off while in gear.. Reconnect after you leave Canadian Tire or leave it. Canadain Tire will not pass the vehicle if rhe DRL can be switched off.
warthogcrewchief
Feb 20, 2015 6:12 PM
David_lee1993
Nov 1, 2012 11:06 PM
chvy_boi
Feb 28, 2009 11:05 AM
gerkendave
Nov 3, 2008 11:36 AM
slbarnesjr
Jul 25, 2007 9:52 AM
Top
Follow Us
