07 Siverado Ext cab LF door trim pad
I need to replace my LH r-view mirror(heated/power), thanks to some $%^head slapping it with HIS mirror at 20mph. How hard is the LF door trim pad to remove? I have no manual to refer to, and cannot find anything online, that gives me step-by-step instructions. I am assuming that I need to R&R the trim pad, to get at the connector for the mirror. Does it just pop off, with a gentle tug?
Thanks, in advance for the help!
Mikey
Mikey
Give us time, this is not a instant help line, you gave us only 12 hours to reply. Not everyone here may know the answer to your question, and someone who does know will usually reply within 24-48 hour at their convenience.
depends on the actual panel that is in the truck on theose the is a small cover by the latch handle that has a 10 mm bolt and the pull handle has some bolts also if you havt the handle with the silver trim in the middle the silver part pops out to get to the bolts then after you have them out the top corner panel by the mirror pops off that is a good spot to start poppin the clips that hold it to the door you should just have to pull out carefully and work your way around oh yea the lock **** has to come off first also it has a small square in the middle of it pop that square out and it will pull up off the rod
MV
dpainter68
Dec 7, 2012 10:22 AM
mikey v
Mar 14, 2009 9:29 PM
cjeff
Jan 17, 2009 6:54 AM
mikewaterskis
22
Oct 10, 2007 8:47 PM
