'08 2500HD Opening in firewall for wiring to dash?
We have an '08 Silverado 2500HD Z71 LTZ Crew Cab with Duramax. I'm in the planning stages of installing HF/VHF/UHF amateur radio equipment in cab and want to wire directly to the accessory battery under the hood. Is there anyone out there who knows if there is an access plug in the firewall that I can run my single pair 10awg power cord through or am I going to have to drill through the firewall? Thanks for your help..Steve KO4QT
No Fix idea's yet
No one has come up with an idea here on how to get through the firewall yet. I'll most likely end up drilling a hole in the passenger side firewall about 6" or so above the floor bottom. I'll then install a groumet in the hole, run the wires, then seal the hole with silicone caulk. Unless I hear a better idea real soon that is..
themcguire
K5 Blazer
October 19th, 2009 3:58 PM
