08 silverado 1500 4.8 crew cab, any problems?
Old Sep 9, 2009 | 6:55 PM
kyleiscool's Avatar
Default 08 silverado 1500 4.8 crew cab, any problems?
So far Im very happy with my new truck. Im just here to see if anyone has had issues with theres. Ive had one issue with mine, but the dealer fixed it. my issue was every time i would let off the gas being from 40 down to 0 mph then gas it again i would feel a clunk in the rear end. I guess the slip yoke was dry and needed to be lubed. I had a buddy with same truck do the same thing. I was wondering if its a common thing or just happend to ours.
Old Sep 9, 2009 | 11:39 PM
jwruss's Avatar
Very common and GM has apparently come up with a fix if lubing the slip yoke doesn't fix it.
Old Sep 10, 2009 | 12:23 AM
kyleiscool's Avatar
Do you know exactly what they do if lubing it doesnt work? my truck seems to be shifting smoothly right now.
Old Sep 10, 2009 | 4:18 AM
horhay's Avatar
Watch the rear doors.The weather strip used is a poor design and allows a large amout of water to run into the door,likely to get water in the cab.Apply a small continuios amout of water to rear windows and watch how much water runs from drain holes in door.With that much water inside door likely to leak into cab at threshold
Old Sep 10, 2009 | 11:03 AM
kyleiscool's Avatar
fortunatly for that issue i should be fine. it doesnt rain here much. but when it does ill keep an eye out for the leaks. thanks
Delbert51
165
Dec 4, 2015 9:04 AM
dpainter68
Dec 7, 2012 10:22 AM
gjohnson25
Nov 23, 2010 9:25 AM
BRozier11
Sep 16, 2009 2:26 AM
mikewaterskis
22
Oct 10, 2007 8:47 PM
