Notices
08 silverado rear end drop
Old October 9th, 2009, 8:27 AM
  #11
Ride of the Month
May 2009
mudmaniac's Avatar
Originally Posted by jabreu
thanx for the info.also what is this i hear about pinion angle or something like that?how does that work or get fixed?
Removing the stock blocks would have very little impact on the pinion angle, they are only 1 1/2" anyway.
Old October 9th, 2009, 9:27 PM
  #12
Spaz563's Avatar
Ive got an 08 reg. cab and got the 2" drop shackles put on. I haven't had any issues with the alignment or anything. Well worth it.
Old October 10th, 2009, 11:27 AM
  #13
Ride of the Month
August 2009
DeeZ's Avatar
Mods please deal with Asholo.
Back on topic, Have you thought about getting a leveling kit for the truck instead? It will lift the front to match the rear. Just throwing it out there in case you didn't know about it.
Deez
Old October 10th, 2009, 6:37 PM
  #14
Ride of the Month
May 2009
mudmaniac's Avatar
ok i have the 08 chevy silverado and i want to drop the back end to make it level with the front. yes i know ppl say it should be lifted but i just want to level the truck out and just drop the rear. i dont want to lift the front. just want it to look good.
would it be good to just remove the 1 1/2" block thats already installed under the leaf springs or would it be better to just buy the 2" drop shackles? is there any safety hazards with removing with that block? which one does everyone say is safer to do, remove the block or get drop shackles?
Wake up DeeZ, read the original post my friend.
Thinking about that truck you want to buy is messing with your head. JK
Old October 10th, 2009, 9:22 PM
  #15
Ride of the Month
August 2009
DeeZ's Avatar
Whoops!!!!!!
I drove that truck home today btw!
Deez
Old October 11th, 2009, 4:07 PM
  #16
Ride of the Month
May 2009
mudmaniac's Avatar
Originally Posted by DeeZ
Whoops!!!!!!
Deez
I saw your other post, that's cool.
Old April 12th, 2010, 10:47 AM
  #17
bri-man5000's Avatar
Does anyone know if removing the blocks throws off the drive angle?
Old April 13th, 2010, 10:46 AM
  #18
ffmed6134's Avatar
I was told by a shop that an alignment is only needed when you lower the front-end of your vehicle to adjust the cambers. What is the reason for an alignment for a rear drop,
I had mine lowered 2" front & back and about a month later I had it aligned and they did'nt adjust anything on the laser alignment thing, they said it was good.
Old April 13th, 2010, 2:20 PM
  #19
therewolf's Avatar
Pinion angle shouldn't be an issue for you, unless you're lifting the suspension over 3".
One danger inherent in leveling using the rear is, as soon as you add a load to the rear, you're going to throw off the whole front "lean" and alignment.
I was looking at a pickup the other day thinking "What's wrong with this picture?". Then it occurred to me. The truck had been leveled perfectly, and had no lean at all. Weird.
Pickups are supposed to "lean". That's part of the look. (Oh SNAP! That is, as long as the ambassador from France doesn't see it!...)
Old April 13th, 2010, 3:48 PM
  #20
country_09's Avatar
The easiest way to drop the back end would be to just take out the blocks...if you do just make sure the leaf springs line back up in the hole where the blocks would mount or it won't sit right...all in all should only take about 10-20 min. with the right tools...we took mine out and replaced them with bigger ones and took my friends out to drop his like you want to do
TASpinney9110
March 15th, 2011 5:54 PM
hydrodriver
Astro
December 11th, 2010 8:52 AM
Black LS
August 1st, 2007 8:55 AM
2003Tahoe
September 29th, 2006 8:04 PM
wildkatsarz
September 8th, 2006 4:28 PM
Quick Reply: 08 silverado rear end drop
