1987 chev k2500 350 will not stay running
Old Apr 28, 2015 | 8:49 PM
trogg's Avatar
Default 1987 chev k2500 350 will not stay running
Hi,
I have a 1987 (built 3-87) chev K2500 350 engine.Replaced the fuel pump and flilter,cleaned out the tank.Ran initially for a few minutes,then will only run if fuel is dumped in the throttle body.Will the fuel pump on this vehicle cycle for a longer time then current models ? (it seems like it runs a lot).Is it an issue with the throttle body or ignition ? Thanks for the input.
Bob J
Old Apr 28, 2015 | 9:24 PM
Rednucleus's Avatar
My 93 sub did this when the ignition module in the distributor was bad. Would run as long as I poured gas in the throttle body but the module wouldn't fire the injectors
Old Apr 29, 2015 | 9:17 PM
trogg's Avatar
Thanks I was told to replace this and will do this weekend and let you know.
trogg
Apr 28, 2015 8:38 PM
Batmaster
Feb 18, 2013 1:15 PM
starkman1968
Feb 28, 2010 8:11 PM
stinemonster
13
Jun 5, 2009 7:35 PM
ibinazbass
Apr 17, 2008 11:28 PM
