1988 454 sluggish question
Old May 17, 2012 | 1:57 PM
wrightml's Avatar
Default 1988 454 sluggish question
I have a k3500 454 and it is running pretty bad (just bought it three weeks ago) At first it started idling high and hesitating so I put a new TPI on it and set it @.637 volts per instructions that fixed the first problem.
Now it seems the hesitation is at 1/4 to 1/2 throttle position.
Any help would be appreciated
Thanks
Mark L.<O</O
Old May 18, 2012 | 9:08 AM
johntaps's Avatar
Former Sponsor
As you mentioned that engine hesitate at 1/4 and 1/2 throttle position then only thing you have to check is oxygen sensor.
Old May 18, 2012 | 10:18 AM
wrightml's Avatar
Thank you I will replace it over the weekend.
And will update my progress.
Mark
Old May 18, 2012 | 8:21 PM
RacerX's Avatar
What name brand was the Throttle sensor? Some of the name brands are wack right out of the box. TPS may be bad and have a signal range fault which is why you are stumbling on mid-throttle.
And besides you werent sure the high idle was the throttle position problem versus as dirty throttle body or stuck/bad idle speed control solenoid. Dont waste money buying parts you dont need, just give it to me instead.
Fuzy
Mar 21, 2014 12:12 PM
core shift lsx 454
Nov 18, 2012 3:35 PM
heavychevy511
Oct 31, 2012 8:43 PM
woodstockaz
Aug 15, 2010 4:08 PM
SILVERAD01
Apr 23, 2010 9:48 PM
