Last edit by: IB Advertising
- Chevrolet Silverado 2007-2013: How to Install Front and Rear Shocks
Step by step instructions for do-it-yourself repairs.
1989 Chevrolet K2500 4x4 -- shocks too short?
![Thumbs up](https://chevroletforum.com/forum/images/icons/icon14.gif)
Bought a pair of Grabriel G-63609 shocks for the front end of my unmodified 1989 Chevrolet K2500 4x4 Pick-up Truck. These shocks are fully extended when at rest. Would this explain the front end noise--a banging when the shock reaches full extension after the compression of a bump? Seems that the shock should be 4 inches longer. Source for correct shock--can't get the shock length from any of the online shock manufacturers, they just list the product for the vehicle?
Hi Don,
Welcome to the Chevy Forums.
Since you had a tech question, I posted it here in the Full-Sized Pickup section, and made my post to bring it to the top of the field.
I went to the Gabriel site and verified your parts choice, it was correct.
I can only think of three approaches to the problem. First, most gas shocks are packaged with a nylon cable strap or plastic restraint to hold the shock in the compressed position in order to prevent the nitrogen gas from escaping. Were your shocks still packed in the compressed position when you got them? If so, there's almost no way the gas could have leaked out.
As to the unmodified suspension-do you have your RPO codes translated yet? Possibly the truck came stock with a small lift which isn't included in the Gabriel catalog for that year. You could try the VIN translate at the beginning of the Tech section to see if your truck was assembled with a rare production option. More common now since the "HD" models, are "HVY" -HD option 2 inch body raise, and "Z85"-Chassis Package-High Payload,Firm Ride, for instance.
If you have IFS, what size are your tires? Is it possible that a prior owner installed a higher profile tire, by torquing the torsion bars to raise the front end? In many cases with the heftier pickups, no adjustment to the rear would be needed to install beefier tires. But it would solve the mystery of the shocks not fitting with zero suspension modifications...
![Cool](https://chevroletforum.com/forum/images/smilies/cool.gif)
Hi Don,
If you have IFS, what size are your tires? Is it possible that a prior owner installed a higher profile tire, by torquing the torsion bars to raise the front end? In many cases with the heftier pickups, no adjustment to the rear would be needed to install beefier tires. But it would solve the mystery of the shocks not fitting with zero suspension modifications...![Cool](https://chevroletforum.com/forum/images/smilies/cool.gif)
How can I get shocks that will fit--can I just add 4 inches to the length of the at rest position? But even then how do I find them since shocks are always (?) sold according to the vehicle and not to length and end fastener type? Go to an off-road shop and pay big $$$$?
Don
Yes, IFS= Independent Front Suspension, in the case of the Silverado/Sierra, with torsion bars.
So the tires are stock, and no prior owners haunting you.
Try some thread searches here, and give it a few days to get some input from other members who may be more familiar with this year truck
To get your VIN read, post in the "Please read my VIN" thread hosted by ShawnVW at the beginning of the CF Tech Section. It seems as is you may have located the pertinent RPO code already, however.
Don't be discouraged, you may be able to return the Gabriel shocks for store credit since they didn't fit as promised. Furthermore, the 4X4 shops I've been to haven't been too piratical. They do tend to horn ya for full retail, howsomever
For Sale: 1989 Chevy K2500.CT.FRESH!!
fatkidracing
November 8th, 2010 10:15 AM
suburban3
June 16th, 2010 12:07 AM
jrsavoie
February 24th, 2010 2:38 PM
Tatersalad
March 20th, 2009 6:37 PM
