1989 silverado blowing heater fuses
Old Nov 22, 2011 | 2:44 PM
scrappt's Avatar
Default 1989 silverado blowing heater fuses
My 89 silverado keeps blowing the heather/ac fuse I have replaced the Blower motor resistor and the heather control. this is what happens
I reset the heather conrtol so everything is set to low fan and temp is in the middle. I do this by disconecting the battery ir just disconenecting the heater control then putting it back. I then turn on the truck every thing seems to work fine I can even go Days. i can adjust the heat and where the heat is directed . This is where i blow a fuse I hit the fan button to change the speed some times it will stay on for a few mins some times it will blow a fuse right away..That when i changed the resistor. still did the same thing so i decided I Disconect the blower its self just to see and it still blows fuses. that when i decided to try the heater conrtol got a used one and Still does it . Is there any thing else i can look for..OH and if the truck is on and ideling when the fuse blows it almost stalls the truck..
any help would be great please.
thank you
flukester
Aug 31, 2012 4:38 PM
ds76
16
Jun 9, 2010 6:48 AM
netty
Oct 23, 2009 12:04 AM
mychevyvan
Oct 23, 2006 1:02 PM
