1990 chevy K1500 timing
Old Dec 13, 2012 | 4:32 PM
rparks72's Avatar
Default 1990 chevy K1500 timing
I hope someone can help me. I have a 1990 chevy K1500 pickup with a 5.7 liter. When I have the timing wire plugged up it will not run right, it misses terribly, shakes, will not rev up and will backfire. I can unplug the timing wire and it will run fine, wont miss and rev up fine. I have changed the distibutor, knock sensor, esc module, egr valve, map sensor, ecm, egr control module, wires, plugs, cap and button with the same results every time. Someone please help its my only vehicle.
Last edited by in2pro; Dec 13, 2012 at 5:00 PM. Reason: added a more specific title to thread
Old Dec 13, 2012 | 4:54 PM
kevinkpk's Avatar
What is a timming wire? Can you be more explicite, or photo images?
Old Dec 13, 2012 | 4:58 PM
Are you not using and inductive timing light, the kind that just clips over the jacket of the spark plug wire? If you are interrupting the spark to adj the timing then that is what is most likely causing the mis-fire
Old Dec 13, 2012 | 5:09 PM
kevinkpk's Avatar
If thats the case, if he's not wearing heavy gloves, he's getting his a-- knocked off him.
Old Dec 13, 2012 | 6:29 PM
Allan In NE's Avatar
Harmonic balancer has slipped, or the timing chain is WAY loose.
Allan
jmms
HHR
Apr 17, 2015 4:22 AM
boe402u
Astro
Oct 3, 2013 12:50 AM
6wheeldrive
Sep 26, 2013 11:03 PM
greg jones
Sep 26, 2009 9:25 AM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
