1992 chevy 2500 duelly
my dads 1 ton has pooped out on us! it will not start.. it done this last year. he added some of that gas treatment stuff to get water out and clean wahtever is making it do this .. and it worked. this year we added it and we cant get it to fire at all!.. we have used starting spray. nothing!!! we plan on getting new plugs and wires as soon as the snow melts(wont be soon since we are getting 5-8 tonight).. it will backfire thru the breather everynow and then. im suspecting its the plugs n wires. it sounds like it wants to fire everynow and then it'll speed up in RPM like its about to fire but nothing.. anybody got anythign of this? its got a 5.7 gas engine.. and befor this it was acting up real bad.. missing even warmed up.. any help would be nice thx guys
fuel pressure check, change fuel filter, plugs, wires, cap, rotor, air filter. check timing if you can get it running, but remember to put ecm in "bypass" mode. (there's a tan color wire that is basically the computerized advance. on my "94 silverado it was on in the main harness for computer on passenger side, inside cab. single tan wire with connector. it will set a code while running, but this will allow you to set timing to spec. plug it back in when you're done, reset to erase code.) also check all vacuum lines for leaks, breaks, check all sensor connections. good luck gotstylez. and congrats on "promotion"
me 1 gmc 0 lol.. i win! muahaha got it running! hard to start it tho.. it was smoking real bad. smelled like oil burning and the plugs i pulled out was a light brown and on the threads was a real dark brown.. they needed changed. and also on the coil wire on the dis. cap it was corroded .....so good game gmc..but i win
cr250guy70
December 6th, 2013 7:49 PM
fur_fenton
June 2nd, 2009 10:10 AM
weroll
December 27th, 2007 11:11 AM
