1992 chevy truck misses when it warms up
Old Mar 10, 2011 | 2:47 PM
derby311's Avatar
Default 1992 chevy truck misses when it warms up
i have a 92 chevy truck with a 350..it starts and runs perfect when cold but when it starts to warm up and you give it gas it starts missing and backfires up through the motor..has new plugs, plug wires, and fuel filter
Old Mar 10, 2011 | 5:36 PM
loosebearing's Avatar
Try changing coolant temp sensor... located beside of thermostat housing.
This little sensor has all sorts of symptoms.. cost about 10 bucks.
Get it out of the equation. See if it helps.
Old Mar 11, 2011 | 4:28 PM
derby311's Avatar
changed coolant sensor didn't make any change...also forgot to add that after you drive it around and get it warm then shut it off its very hard to start...anyone know what else it could be...
Old Mar 11, 2011 | 8:23 PM
Check fuel pressure 9 to 14 psi. Could be map sensor. Check coil maybe getting hot.
But sure has symptoms of cts.
Old Jun 18, 2012 | 4:50 PM
Andy64's Avatar
Default 1992 chevy pickup that is missing when it warms up.
Did anyone figure out this problem, I know it not the throttle positioning sensor. Please need help?
Old Jun 18, 2012 | 4:52 PM
Andy64's Avatar
Did you ever figure out the problem? Please let me know if you did.
Old Jun 20, 2012 | 2:35 PM
derby311's Avatar
the tips on the inside of the dis. cap was dirty..
harvester
Jan 11, 2015 2:39 PM
bluefan89
Oct 22, 2014 5:19 PM
awiley93
Dec 9, 2013 1:12 PM
Chevyaz
Mar 21, 2012 9:55 PM
Dirtbike768
Mar 25, 2009 10:51 AM
