1993 k1500 starting problems
Old Jun 6, 2007 | 3:34 PM
runge_24's Avatar
Default 1993 k1500 starting problems
The truck won't turn over, or do anything when the key is turned. We had the starter tested, and it tested out fine. We also replaced the solonoid that is on the starter. Does anyone know what might be the problem or what to look for?
Old Jun 6, 2007 | 5:42 PM
RonH's Avatar
Default RE: 1993 k1500 starting problems
Have you checked/ cleanedthe battery terminals? Even when the connection looks and feels tight and good,if they are corroded or even a little bit loose, all the lights and gaugeswill work, but your starter won't do a thing.
Old Jun 6, 2007 | 6:28 PM
trolea1234's Avatar
im having the same problem with mine, 1993 1500, starter is good, battery is good, connections are good, changed the ignition switch, still wont do anything, it will start if i jump the solonoid, any ideas?
Old Jun 6, 2007 | 10:59 PM
golfer's Avatar
Check the wires from the ignition to the solenoid.
Old Apr 9, 2014 | 1:23 AM
rbyess's Avatar
Default try this
had same problem with my 93 1500 , found the main power feed under the hood had a broken wire just below the fusable link and the dash was not getting any power , under hood on left side of firewall is a row of wires with fusable links . may need to use a manual to find the wire that feeds the ignition switch and dash
93K1500
Nov 18, 2020 12:47 PM
Bryan6952
Dec 9, 2012 7:44 PM
1993Chevy1500Z71
Jul 20, 2010 9:07 PM
Clutch
Jun 14, 2010 11:49 PM
broknindarkagain
Jul 10, 2009 11:25 AM
