1993 silverado dies then comes back to life a day later.
Hey guys
I need help please.
My 93 350's problems started about a month ago. It died on me and would not start for crud! Waited the next morning and tried it just for the hell of it. It started Yahoo
! Almost it died again in about 2miles
I figured it would be the pump, but i have fuel coming out of the injectors. So i have pressure, not sure how much. i changed the rail fuel filter about 6 weeks ago, as well as regular maintenance, oil, plugs wires, cap, and rotor.
Any ideas would be thankful.
223000 original on motor and tranny.
2nd owner oil changes on regular basis.
Thanks
I need help please.
![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
Thanks
Ok update.
I dont have pressure gauge for the TBI, the three main auto stores dont have it. so this is what i have done so far.........fuel pressure regulator kit installed, Idler air control valve,and new fuel pump and filter.
Still nothing!
Dagnabit! what else could it be?
Please someone give me an idea.
This is makeing me upset
Still nothing!
There is a relay on the firewall that sometimes goes bad, you could check that, but that sounds like a fuel pump problem to me. Did you change the fuel pump wiring when you changed the pump? Just an idea/
Thanks for the help doitinthedirt: Yea its fine i can hear the pump when key is in acc.
I think its the ignition coil i saw no lightning last night through my screw driver. so i think it has gone out.
If anyone can help I would really appreciate it. Changed ignition coil,cap,rotor timing chain and gears.
Still no spark could it be my ICM? or just a bad ground somewhere?
help please
help please
![Exclamation](https://chevroletforum.com/forum/images/icons/icon4.gif)
If any one cares....... The problem was the I C M !![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
This forum is sad! ![Frown](https://chevroletforum.com/forum/images/smilies/frown.gif)
Not much help here.![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Going back to the NATIONS!![Cool](https://chevroletforum.com/forum/images/smilies/cool.gif)
www.powerstrokenations.com
A helpful (real) forum.
![EEK!](https://chevroletforum.com/forum/images/smilies/eek.gif)
93/k1500/4x4/5.7L
September 26th, 2022 3:33 PM
ontheway
September 16th, 2013 8:57 PM
brenande
January 27th, 2008 12:40 AM
