1993 silverado dies then comes back to life a day later.
Old Jun 15, 2011 | 3:23 PM
branch's Avatar
Default 1993 silverado dies then comes back to life a day later.
Hey guys
I need help please.
My 93 350's problems started about a month ago. It died on me and would not start for crud! Waited the next morning and tried it just for the hell of it. It started Yahoo! Almost it died again in about 2miles.
I figured it would be the pump, but i have fuel coming out of the injectors. So i have pressure, not sure how much. i changed the rail fuel filter about 6 weeks ago, as well as regular maintenance, oil, plugs wires, cap, and rotor.
Any ideas would be thankful.
223000 original on motor and tranny.
2nd owner oil changes on regular basis.
Thanks
Old Jun 15, 2011 | 8:25 PM
OLD WRENCH's Avatar
Any codes? Check the fuel pressure it HAS to be within specs to work right.
Old Jun 21, 2011 | 5:41 PM
branch's Avatar
Ok update.
I dont have pressure gauge for the TBI, the three main auto stores dont have it. so this is what i have done so far.........fuel pressure regulator kit installed, Idler air control valve,and new fuel pump and filter.
Still nothing!
Dagnabit! what else could it be?
Please someone give me an idea.
This is makeing me upset
Old Jun 21, 2011 | 11:42 PM
doitnthedirt's Avatar
There is a relay on the firewall that sometimes goes bad, you could check that, but that sounds like a fuel pump problem to me. Did you change the fuel pump wiring when you changed the pump? Just an idea/
Old Jun 22, 2011 | 3:07 PM
branch's Avatar
Thanks for the help doitinthedirt: Yea its fine i can hear the pump when key is in acc.
I think its the ignition coil i saw no lightning last night through my screw driver. so i think it has gone out.
Old Jun 23, 2011 | 6:35 AM
branch's Avatar
If anyone can help I would really appreciate it. Changed ignition coil,cap,rotor timing chain and gears.
Still no spark could it be my ICM? or just a bad ground somewhere?
help please
Old Jun 23, 2011 | 11:12 PM
branch's Avatar
Exclamation
If any one cares....... The problem was the I C M !
This forum is sad!
Not much help here.
Going back to the NATIONS!
www.powerstrokenations.com
A helpful (real) forum.
93/k1500/4x4/5.7L
Sep 26, 2022 3:33 PM
Matt Schutz
Sep 1, 2015 6:17 PM
ontheway
Sep 16, 2013 8:57 PM
brenande
Jan 27, 2008 12:40 AM
