1994 chevy k1500 truck help needed
Old Nov 4, 2009 | 3:07 PM
tecate1987's Avatar
Default 1994 chevy k1500 truck help needed
1994 chevy truck 4.3 vortec engine, 5 speed. 150psi compression No check engine light on, yes it works.
Truck is offroad plow truck only.
Truck is running rich, mostly seems like the passinger side not firing. I can take off 2,4 and 6 wires and no change in engine. Smoke smells of raw gas coming out exhaust. truck barely moves. wont hold idle anymore.
Changed: plugs, wires, temp sensor, dist cap and rotor.
I have found posts saying lines in the plenum maybe leaking.
WHat can cause this to run like this ?
I'd like to know is if this truck has those lines inside the plenum? Or is this just a regular intake ? are the lines under the intake or just the throttle body ?
Here is pic of engine, throttle body injected
Attached Thumbnails 1994 chevy k1500 truck help needed-mvc-002s.jpg   1994 chevy k1500 truck help needed-mvc-003s.jpg   1994 chevy k1500 truck help needed-mvc-004s.jpg
Old Nov 4, 2009 | 10:19 PM
SGTBRYAN.WISE1's Avatar
You might want to hook up a fuel pressure tester to see what the pump psi is... it could be a bad inj, fuel pressure reg......
Old Nov 12, 2009 | 4:03 PM
tecate1987's Avatar
Default 02 sensor
this has a 3 wire 02 sensor in front on the cat.
how do I determine which is heated wire, signal and ground ?
propaneman
Sep 7, 2015 6:46 PM
ssimas
May 10, 2015 10:01 PM
notrefined
Sep 28, 2014 9:12 AM
mps2220
Jan 2, 2014 1:13 PM
94chevytk
Jan 9, 2010 12:12 PM
