1994 Cheyenne 2500 5.7L Automatic
Old Aug 7, 2024 | 10:49 AM
L@MTMR's Avatar
Default 1994 Cheyenne 2500 5.7L Automatic
I'm sure I will miss some important details, I will update as needed.
This is my work truck, I need it running well ASAP. As I am driving aprox 65-70 mph I will have light pressure on the gas. At random the dash gauges go nuts, the RPM plummets and "Service Engine Soon" light kicks on. I let off the throttle then it picks back up, I reapply but it just revs very high and is out of gear. I let off again and it will grab a gear and go back to normal. I have no idea what is going on, I am looking for tips on where to start.
I wasn't having any issues a few weeks ago. I took the truck into a shop to get the AC fixed and the mech told me he had to bypass something the head unit. After he did that all the gauges will go crazy randomly. I didn't immediately have these shutting down issues though. He told me he followed GM Bulletin #92-201-1b.
Old Aug 7, 2024 | 10:52 AM
jfmorris's Avatar
Sounds like an electrical problem to me. One problem on these older trucks (I have a 1996 Cheyenne C1500) is degradation of the grounds, and broken ground straps under the hood. Since it is likely a 4L60E or similar transmission when there is an electrical glitch, the electrically controlled solenoids in the transmission will probably get reset, and you will be out of gear.
I would double check ALL connectors under the hood, and look at the grounds closely as well.
Old Aug 7, 2024 | 11:01 AM
L@MTMR's Avatar
I'll look into that today, thank you.
Old Aug 8, 2024 | 6:39 PM
L@MTMR's Avatar
I blew a tire and had to get that taken care of first, but I had some time to dig into it today. I found a spot near the brake pedal that has dozens of wires running through the firewall. Some were in connectors and others were run in loom through it. I found that the large plastic connector where most of the wires from the cab run to the hood had two screws coming loose, I tightened them down and that seems to have solved the problem. I assume many of those ground through the connector. I took it on a test drive and everything seems to be working.
Im defentily going to keep poking around but hopefully I got it. Thank you for your help.
Old Aug 8, 2024 | 10:26 PM
jfmorris's Avatar
Sounds like you found the issue. Glad it was that simple!
Wiliam Miller45
1988 - 1998 (GMT400)
Jul 19, 2020 3:40 PM
Caleb1534
Jul 26, 2018 1:32 PM
k_grantham10791
10
Jan 11, 2014 1:18 PM
riburban
Dec 11, 2012 12:21 PM
94chevytk
Jan 9, 2010 12:12 PM
