1994 k1500 transmission help
Old Jan 9, 2010 | 11:27 AM
94chevytk's Avatar
Default 1994 k1500 transmission help
im looking to put a 4 or 5 speed in my truck soon and need help figuring out which transmission to use. im converting to manual because automatic keeps slipping in second and even after getting it rebuilt in 2006 it started slipping 30,000 miles later. does anyone know which transmission i should look for and anyone that has done this do you know what else i'd have to change to keep the truck running correctly without dash light codes?
truck is 1994 K1500 4x4 350
Old Jan 9, 2010 | 12:12 PM
myotherchevyisablazer's Avatar
i would look for a nv4500
that is alot of work converting to manual from auto....good luck
http://www.nv4500.com/
Early GM units (93-94) were built with a lower first gear ratio of 6.34 to 1.0. These low-geared GM boxes have since been discontinued and are generally much more difficult to obtain. We are able to provide new and remanufactured NV4500s with these early gearsets.
Beginning in 95’, all GM units were built with the same gear ratios as the Dodge unit.
<TABLE border=0 cellSpacing=2 cellPadding=2><TBODY><TR><TD> </TD><TD bgColor=#c0c0c0 align=middle>GM 93-94</TD><TD bgColor=#c0c0c0 align=middle>95/up GM; 93/up Dodge</TD></TR><TR><TD bgColor=#ffffe7>First Gear</TD><TD bgColor=#ffffe7 align=middle>6.34</TD><TD bgColor=#ffffe7 align=middle>5.61</TD></TR><TR><TD bgColor=#ebebeb>Second Gear</TD><TD bgColor=#ebebeb align=middle>3.44</TD><TD bgColor=#ebebeb align=middle>3.04</TD></TR><TR><TD bgColor=#ffffe7>Third Gear</TD><TD bgColor=#ffffe7 align=middle>1.71</TD><TD bgColor=#ffffe7 align=middle>1.67</TD></TR><TR><TD bgColor=#ebebeb>Fourth Gear</TD><TD bgColor=#ebebeb align=middle>1.00</TD><TD bgColor=#ebebeb align=middle>1.00</TD></TR><TR><TD bgColor=#ffffe7>Fifth Gear</TD><TD bgColor=#ffffe7 align=middle>0.73</TD><TD bgColor=#ffffe7 align=middle>0.73</TD></TR><TR><TD bgColor=#ebebeb>Reverse</TD><TD bgColor=#ebebeb align=middle>6.34</TD><TD bgColor=#ebebeb align=middle>5.61</TD></TR></TBODY></TABLE>
red
propaneman
Sep 7, 2015 6:46 PM
tecate1987
Nov 12, 2009 4:03 PM
94blazerz
Jan 31, 2008 1:45 PM
seanharlow
Oct 13, 2007 4:23 PM
beatsie
Jul 4, 2007 5:45 PM
