1995 1500 Chevy K blinker (light) does not work
Old Mar 21, 2008 | 6:22 PM
larbec7's Avatar
Default 1995 1500 Chevy K blinker (light) does not work
I have a 1995 1500 Chevy K truck V6 and the rear drivers side blinker (light) does not work. I replaced the bulb and it worked "Once" and then it blew again. Is their a relay in the circuit or possible do I have a short?
If anyone has any ideas I am open ears.
Thanks so much in advance!!
Old Mar 21, 2008 | 7:03 PM
TransAm Man's Avatar
Default RE: 1995 1500 Chevy K blinker (light) does not work
It sounds like you got short, probably the ground side of the blinker is shorted to a 12 volt reference. It's a pain in the *** checking yourself, a mechanic will do it for you for $100 or less
Old Mar 21, 2008 | 8:19 PM
rockmaples's Avatar
My truck had a similar problem.
If you have the push in type of lights, try pulling out the contacts on the board where the bulb meets it. Sometimes they can rust and lose contact.
I did this and stuffed in some lithium grease a few years ago and there have been no problems since.
P
goyakpacking
May 9, 2015 7:51 PM
tony72
Nov 17, 2014 11:37 AM
shant
Feb 23, 2011 9:08 PM
1LooseLugNut
Aug 15, 2010 6:46 PM
Barreno23
Oct 19, 2008 9:22 AM
