1995 Chevy ring job
Old Jan 2, 2011 | 7:58 PM
slbsgt's Avatar
Default 1995 Chevy ring job
I picked up a hunting truck "Harry" it was full of dog hair when I got it and the kids named it, anyhow its burning alot of oil, no leaks just burning, I went 500 miles and was down 3 quarts, Anyone give me an idea on the cost of a ring job? Compression seems to be good but you can smell the burning oil when you stop. Anyhelp would be appreciated
Old Jan 2, 2011 | 8:01 PM
slbsgt's Avatar
it has 350 5.7l engine, 193000 miles
Old Jan 2, 2011 | 11:22 PM
OLD WRENCH's Avatar
Default using oil
Engines run so long anymore that by the time they need rings they need a lot more like boring,pistons,valveguides,ect. To get an estimate go to some shops in your area. If its just a beater you might consider a used engine.
Old Jan 8, 2011 | 4:34 PM
jahseminole's Avatar
Default I'm having the same issue
I bought a '95 silverado with 80K miles and it's having the same problem. I can't find a leak, but i'm losing oil somewhere. Just had an oil change, but 30 days later I had to add three quarts to see a measureable level on the dip stick. Could this be a problem with this year/make??
Old Jan 8, 2011 | 5:26 PM
gotstylez's Avatar
well guys the trucks are 16 years old.. lol what do u expect? my 95 will start burning a little if you dont change the oil at around 4500k miles but then again i think anything will. might wanna try thicker oil??? i had a ol 77 ford that burned oil real bad i put some 10w-50 and it still burned it..but not as much
Old Jan 9, 2011 | 11:47 PM
2wd-K5's Avatar
gotstylez is right they are just old, now before you go and buy new engines or tear them down for a rebuild take a compression test, if compression is around 150 all the way around, it could just be the valve seals or worn guides
Chevrolet Forum News
Jan 28, 2015 1:18 PM
Nov 5, 2014 12:08 PM
Nov 6, 2013 3:08 PM
macraigm
Jun 1, 2012 12:50 PM
dlatner
Jul 12, 2006 5:50 PM
