1995 Chevy Silverado Heater Problems
Well i am having a heck of a time getting my heater to blow out hot air. I have replaced thermostat, Dbl checked fluid level, and checked blower motor.
but all it dose is blow out cold air not sure what step to take now? if anyone could help me with this i would greatly be thankful as it is 15 out and hard to drive to work in the mornings. ty
But if your heater core is bad then gettin heat will be a problem.
Check the heater core for sure.
Well i have did some digging and found out my blend door is not moving so i haave searched for hours and cant find a fix for this. Is there a way to just move it to the right place. iIdont use my a/c much would rather just have the heat. ty Parasite
From what I have learned and heard, I could be wrong but.... The blend door is all electrical and is a low volt system. i could be wron as i have a 96 and think that is the year that they changed the dash and some other things, however the blend door does not work on an older style rod system it is an electric motor.
my thoughts were the same since I dont have heat was to maybe jump the door to the open condition, not a good idea you can fry the motor and maybe more. Just my 2c
New User
Awaiting E-mail Confirmation
if you take the actuator off you can control the door by first turnig heater to full blast then removing glove box and turning the little white plastic **** by hand but if u turn the truck off you will have to do it again
Dont confuse apples and oranges. You have a blend door that directs the air over the heater core or AC evap, then you have a mode door that directs the air to the floor vents,defroster,ect.
joandkent
January 29th, 2017 8:51 AM
Radical
April 14th, 2013 3:39 PM
FATBOB316TX
September 28th, 2010 1:54 PM
oehq.com
March 25th, 2010 4:10 PM
