1995 k1500 5.7 350 power loss
have problem getting up to speed on highway thought transmission trouble . no lights on dash.At a stop put in drive and power braked it and slowly increased the throttle and then started missing.
New coil pack with all that?
also have you checked the manual adjuster on the throttle cable?
also for shts and giggles, while it is running spray around the intake with carb cleaner, if the idle changes when you do that your intake gasket is kaput, if not then that gasket is not the culprit.
My husband has a 95 silverado, with a loss of power going up hills and normal acceleration. It will idle and purr like a kitten, but when you step on gas it wants to bogg down and try to cut out.
chaz56
Apr 30, 2015 11:44 AM
Tlindsey099
Oct 7, 2013 10:36 PM
rteas48183
Mar 18, 2008 4:59 PM
