1995 k1500 5.7 350 power loss
Old Aug 14, 2014 | 11:26 AM
diver8718's Avatar
Default 1995 k1500 5.7 350 power loss
have problem getting up to speed on highway thought transmission trouble . no lights on dash.At a stop put in drive and power braked it and slowly increased the throttle and then started missing.
Old Aug 14, 2014 | 5:01 PM
Ronin1014's Avatar
Start out with new spark plugs and wires.
Old Aug 14, 2014 | 7:49 PM
diver8718's Avatar
did that new plugs cap, rotor, wires tps module. still bogs even in neutral wont reeve past 3 thousand rpm?
Old Aug 15, 2014 | 11:10 AM
Ronin1014's Avatar
New coil pack with all that?
also have you checked the manual adjuster on the throttle cable?
also for shts and giggles, while it is running spray around the intake with carb cleaner, if the idle changes when you do that your intake gasket is kaput, if not then that gasket is not the culprit.
Old Aug 19, 2014 | 10:16 AM
diver8718's Avatar
found the problem.....the catalytic converter!!!!! cut it off replaced it
Old Jan 13, 2015 | 5:15 AM
crawford44's Avatar
Default 95 silverado loss of power
My husband has a 95 silverado, with a loss of power going up hills and normal acceleration. It will idle and purr like a kitten, but when you step on gas it wants to bogg down and try to cut out.
chaz56
Apr 30, 2015 11:44 AM
Tlindsey099
Oct 7, 2013 10:36 PM
Unknown1329
Nov 17, 2011 8:37 AM
cvfc1216
Sep 30, 2009 1:01 AM
rteas48183
Mar 18, 2008 4:59 PM
