1995 k1500 odometer runs in park
Old Feb 17, 2010 | 11:10 PM
uproar1's Avatar
Question 1995 k1500 odometer runs in park
I have a 1995 k1500 4x4 with a 4.3 v6 ,auto transmission and manual transfer case.. When in park if you rev the engine slightly the trip counter and the odometer start to turn... Also the idle is horrible the truck runs fairly well throughout the driving range but once in a while when you try to start it acts as though it is mechanically out of time...then it just starts up fine.... Any ideas???????
Old Feb 17, 2010 | 11:59 PM
nauticstar87's Avatar
I thought the Odometer ran off the MPH sensor at the rear of the trans.
that just sounds odd. I did some googling, but i couldn't find anything similar.
Old Feb 18, 2010 | 12:05 AM
uproar1's Avatar
Default weird
i thought it was mechanical but apparently it is not... it does not move when idling but if you give it a little gas the trip meter odometer and speedometer start to move plus it is really running like crap down at idle but runs fine the rest of the time.......could it be a speed sensor????
Old Feb 18, 2010 | 12:22 AM
Maybe, is the check engine light on?? If so have the codes ran, sometimes the codes will give the exact problem, or at least help pin point it.
Old Feb 18, 2010 | 1:36 AM
uproar1's Avatar
Default no check engine
no check engine but the abs light is on
hardhead
Apr 6, 2015 10:21 PM
jrobpush
Mar 22, 2013 10:37 AM
Chevy Newb
Feb 18, 2011 6:32 PM
SGTBRYAN.WISE1
Nov 4, 2009 10:13 PM
rteas48183
Mar 18, 2008 4:59 PM
