1996 Chevy 1500 wont start
ok i bought this chevy last month, the motor in it backfired on the guy and broke upper intake and everything else plactic on the thing.the motor was a 305 and i just got a newely rebuilt chevy 1996 350 5.7. i dropped it in. hooked everything up. i used my lower intake from my last motor on it and the injectors from the 305 cause i was told they would work. well i got it all in and now it wont start. cranks well. i got good fuel pressure. it stumbles but wont start. timing looks fine. cant figure out what to do, i had a mechanic come look over it and it baffled him. it sometimes backfires a little to. any help would be great...
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
so at TDC, the dizzy pointer is pointing directly at #1 cyl? what does the spark look like? is it strong looking? or is it weak? how are the grounds? if the grounds are loose, or bad, or not there the engine wont run, also, how does the fuel injectors look while you are trying to fire it? is it a nice cone? or all scattered?
how do i check the fuel injectors? strong spark
ok so after trying to start it for a wile i pulled my # 1 plug out and it was dry which makes me believe its not getting fuel. i also pulled my # 4 plug which was coated in fuel. what would cause this... fuel injectors or the timing again
i tried it again and checked all my plugs. 2,4,6,8 plugs are all getting fuel. so are 5,7 on the left side. but my 1 and 3 are not
