Notices
1996 chevy 5.7 2wd
Old February 25th, 2014, 2:04 PM
Rasekane's Avatar
Default 1996 chevy 5.7 2wd
I have a 96 chevy 5.7 i have just changed fuel sending unit and pump, brand new dizzy crank and cam shaft sensor new rotor and cap, plugs and wires are realatively new as well, still has a miss and at time will backfire any ideas???
Old February 26th, 2014, 10:20 AM
fredrich03's Avatar
I have experienced bad plugs from parts stores,, only get them from a dealer now!
Plug wires on correctly?
Just suggestions.
Old February 26th, 2014, 10:32 AM
Pugly's Avatar
does the check engine light come on??
I would have the PCM scanned for codes - including history codes and go from there....
make sure that #5 and 7 plug wires aren't crossed too.....
Old February 26th, 2014, 12:19 PM
Rasekane's Avatar
Just suggestions.
Thanks, yes everything is on correctly, i thought about the plugs as well i may try that...
Old March 11th, 2014, 9:34 PM
95chevyTN's Avatar
I would say maybe try the distributor. If you have put a new rotor and cap along with plugs and wires on it, then that is the only other thing that I can think of that could be wrong/making it miss.
dmk
July 7th, 2013 1:27 PM
Travis316
December 17th, 2012 9:01 PM
albert88
October 11th, 2009 1:30 AM
Quick Reply: 1996 chevy 5.7 2wd
