1997 1500 4.3L stumbling and missing
Old Feb 16, 2013 | 7:56 PM
jordan.morgan's Avatar
Default 1997 1500 4.3L stumbling and missing
ok so here the issues the truck will start idle and rev fine,when I pull out it does fine till it hits about 2000 RPMs then it starts stumbling and the shift light comes on. Once i shift it will do fine. Till the same RPM Range, However if i give it more gas and pass over to about 3000 RPMs then it runs like a top. problem only seems to be at near 2000 RPMS. At highway speed that is cruising RPM. so this is a issue.
We have had plugs, wires and rotor button and Cap and coil all replaced and no change MAF sensor and fuel filter and pump replaced and no change.
I need Help Im racking my brain here....
Old Feb 17, 2013 | 8:54 AM
Marcus Baker's Avatar
It sounds like the fuel pressure regulator / 'spider assembly' to me.
Old Feb 18, 2013 | 10:20 PM
Yea I was hopeing that would not be the issue how hard is it to replace that
Old Feb 24, 2013 | 10:51 PM
Mike Vosburg's Avatar
Default 1995 missing
I gust hade the same thing replaced oxgen plugs wires roter and cap anb re greesed ele chip
Insjde rotter cap the last helped the most
Cananot
Apr 20, 2015 1:35 AM
BlaneR
Aug 2, 2012 5:23 PM
winkelfish
Aug 23, 2010 8:55 PM
93chevyman
Mar 12, 2010 1:13 PM
Jeff1968
Nov 3, 2007 12:05 PM
