1997 1500 Silverado 5.7L Fuel pump ground wire help
Old Mar 15, 2012 | 11:12 AM
aewf3's Avatar
Default 1997 1500 Silverado 5.7L Fuel pump ground wire help
I am replacing my fuel pump and I need help on finding out where my ground connects to on the frame. I accidentally disconnected it when putting the tank back in it has a connector on the end of it but I have no idea where the connection is on the frame it would help if anyone else has had this same problem or could offer a tip on properly grounding it to the frame and I don't have a soldering gun.
Old Mar 15, 2012 | 5:18 PM
nkh34's Avatar
The ground is on the top of the frame if you pull the wire straight out from the pump to the frame and feel maybe 3 inches toward the front of the truck on top of the frame there is a little hole that has screw threads thats where its at you might have to wipe it down to find the hole though.
monkey23
Dec 15, 2012 12:44 PM
monkey23
Dec 13, 2012 10:48 PM
hunter10220
May 18, 2011 8:37 PM
hometheaterman
Jan 15, 2011 6:37 PM
pete90
Oct 4, 2007 6:12 PM
