1997 Silverado Starting issues
Old Mar 11, 2014 | 2:33 PM
TheEric's Avatar
Default 1997 Silverado Starting issues
New to this forum, could use some advice.
Today I replaced my air filter and filled my fuel tank. After returning home, my truck was off for about an hour. As I went out to start my truck, it did the following.
I turned the key, started normal, however rpm began to bounce, and the truck shook. After appox. ten seconds the truck shut off, remaining on was the aux power. I started the truck again and it did it again. I got out and rechecked around my air filter to make sure no sensors where unplugged, every was connected. I went back to the cab, left the door open and listened for the fuel pump as I started the truck. The truck started, doing the same as before, I could hear the fuel pump running the whole time, no cut out noises from the fuel pump. I'm not sure where to go from this, I did some reading and people where sugguesting checking the wire connectors at the fuel pump and also maybe a ign. switch. Do any of you have any sugguestions.
Thanks in advance for your advice,
TheEric
Old Mar 15, 2014 | 8:11 AM
GMtruckGuy's Avatar
Did you try replacing the fuel filter? As perhaps when you filled up it stirred up some dirt in the tank, or you got a dirty batch of unfiltered fuel. Or there could be water in the gas.
Please let us know what you find was wrong.
Old Mar 15, 2014 | 10:55 AM
You could also try doing a fuel pressure check.
joshm
16
Feb 9, 2015 12:07 PM
bebowl
Jul 30, 2011 2:47 PM
SS70Chev
Dec 13, 2006 2:40 PM
joshm
Dec 11, 2006 11:54 PM
