1998 automatic chevy silverado gear shift stuck in park
my 1998 automatic chevy silverado's gear shift gets stuck in park quite often. I notice the problem to occur more often when the weather is hot. At times the gear shift can get stuck for 10 mins until I get off and push the truck back and forth and for some rare reason itbecomes unstuck. Not sure what the problem is, please help, thanx.
RE: 1998 automatic chevy silverado gear shift stuck in park
my guess is the park pin inside the trans is worn. it will wear like a back cut and cause it to pull itself harder into park if theres pressure on it. that ones gonna need internal trans work to be repaired most likely.
I'd be looking at the ignition switch if I were you. The switches are known to have poor connections internally and I have seen them cause a no shift condition before
mak1na
April 23rd, 2013 11:32 AM
BigblackHo3
April 5th, 2013 8:54 AM
rh6585
June 23rd, 2011 7:54 PM
bdm408
September 7th, 2008 6:24 PM
