1998 K1500 5.0 Vortec loss of power
Old Aug 26, 2012 | 9:21 PM
chaz56's Avatar
Default 1998 K1500 5.0 Vortec loss of power
Hey Guys,
I just bought a 1998 K1500 5.0 Vortec the truck starts and sounds fine until the truck is about to shift gears. The truck starts to hesitate at Higher rpms if you let off the throttle and let it shift and give 1/4 throttle it runs ok. If you floor the gas, once it goes past about 3-4k rpms the power is gone the motors screaming but not going any where. Check engine light is on and was reading miss fire and egr valve. I changed distributor cap, rotor, plugs, wires and egr valve after all that the truck still is hesitating at higher rpms. Engine light went away till I went on the high way and the truck was working hard to get to 65 and the light came on. Can this be a mass air flow sensor or throttle position sensor? Can someone steer me in the right direction this truck mechanically seems fine I know it has to be some type of sensor or maybe clogged cat? Please help thanks
Old Apr 29, 2015 | 10:11 AM
XSpyderDragonX's Avatar
Default Did you get it fixed?
Hey, I am having the same problem with me 98 GMC Sierra 5.0 vortec. Just wondering if you ever got it fixed, if you did what was the problem? Lemme know when you can, thank you.
Old Apr 30, 2015 | 10:56 AM
chaz56's Avatar
The cat converter was clogged. It ran like a top once I installed a New one.
Old Apr 30, 2015 | 11:44 AM
Awesome! Thank you for your help!
diver8718
Jan 13, 2015 5:15 AM
Tlindsey099
Oct 7, 2013 10:36 PM
jbrack
Apr 26, 2013 5:15 AM
cvfc1216
Sep 30, 2009 1:01 AM
rteas48183
Mar 18, 2008 4:59 PM
