1999 GMC Transfer case Issues
Old Aug 21, 2011 | 11:48 PM
Dylly's Avatar
Default 1999 GMC Transfer case Issues
I have a 1999 GM SLT half ton with the NP 246 transfercase.. It seems to work fine in 4x4 and shift in/out fine until you drive it up to highway speed (in 4x4) as shortly after i let off the gas and start to decelerate it gives me a 4wd service light and refuses to shift out of 4x4 until I turn the truck off and turn it back on.
The previous transfer case was completely mangled and this one I just put in came out of a 2001 GM...
Like i said it works perfectly fine until I get it up to road speed. 80+km/hr (45+mph)
Ideas?... Oh i did try change the switch with the one out of my 2001 part truck (no difference).
Old Aug 22, 2011 | 10:47 AM
ToooTall1's Avatar
Since you have a parts truck trying replacing the T/C module located behind dash on the left side. Hard to get out but just keep moving it around and it will come out. Normally not bolted or screwed down.
Old Aug 22, 2011 | 1:29 PM
Dylly's Avatar
Well I ended up doing my own diagnosing since i didnt realize i had a reply.. Changed the front output shaft sensor on the transfer case..
Works like a charm now.. I guess the ECM didn't have any idea how fast the driveshaft was spinning and was coding because of it.
Thanks a lot though!
Chev98
May 29, 2014 2:43 PM
Dwyerf
Jul 24, 2013 6:18 PM
jo-e90
Jan 22, 2013 9:21 PM
TX Chevy
Sep 6, 2011 9:26 AM
rowekmr
Aug 7, 2009 12:18 AM
