2000 Chevrolet Silverado Security Light Problem
Help,
My elderly 2000 Chevy Silverado has developed what might become a fatal ailment. One cold snowy day in December the security light came on and has stayed that way. It starts quite readily but will only run for a few seconds. Through online research I've discovered this is a common problem. I've tried all the common suggestions without success.
I've tried the solder a resister in between the ignition switch and the BCM which didn't work. I also tried on the advice of a local mechanic replacing the ignition switch/wiring harness assembly also to no avail. After each change I tried many times over the relearn the code procedure all without any success.
As I said this is an elderly vehicle (15+ years and 400K miles), I'm aware that for a thousand dollars or so (which I don't have) and a visit to the local dealer this nightmare could all go away.
Any help anyone might offer would be greatly appreciated.
Thanks in advance
Alan
Thanks in advance
Alan
joshrichards182
August 11th, 2015 3:11 AM
sabinandmary
February 21st, 2012 10:55 AM
sabinandmary
February 19th, 2012 2:13 PM
colliez28
February 1st, 2011 12:13 PM
