2000 Chevrolet Silverado Security Light Problem
Old Apr 25, 2015 | 5:41 PM
imalan2Alan's Avatar
Default 2000 Chevrolet Silverado Security Light Problem
Help,
My elderly 2000 Chevy Silverado has developed what might become a fatal ailment. One cold snowy day in December the security light came on and has stayed that way. It starts quite readily but will only run for a few seconds. Through online research I've discovered this is a common problem. I've tried all the common suggestions without success.
I've tried the solder a resister in between the ignition switch and the BCM which didn't work. I also tried on the advice of a local mechanic replacing the ignition switch/wiring harness assembly also to no avail. After each change I tried many times over the relearn the code procedure all without any success.
As I said this is an elderly vehicle (15+ years and 400K miles), I'm aware that for a thousand dollars or so (which I don't have) and a visit to the local dealer this nightmare could all go away.
Any help anyone might offer would be greatly appreciated.
Thanks in advance
Alan
joshrichards182
Aug 11, 2015 3:11 AM
janeprovidence
Jul 28, 2013 11:01 PM
sabinandmary
Feb 21, 2012 10:55 AM
sabinandmary
Feb 19, 2012 2:13 PM
colliez28
Feb 1, 2011 12:13 PM
