2000 Chevy 1500 2WD Issues
Old Aug 2, 2013 | 5:37 AM
Captain Amerika's Avatar
Default 2000 Chevy 1500 2WD Issues
*"I have a 2000 chevy 1500 2wd when you start the truck it will start then aost immediately die this morning when it did this then all the lights would go out after I let it set for about 5 minutes you could turn the key and the lights come on and the clock resets
Old Aug 2, 2013 | 6:48 AM
Just got a call from the wife starts now and acts normal WTF? Can anyone help I am at my wits end with this thing I have dropped 1500 dollars in it since january doing a tune up and replacing the fuel pump
Old Aug 6, 2013 | 11:38 AM
Please can someone help me
Old Aug 7, 2013 | 7:20 PM
james.reid's Avatar
Man that sounds like something to do with your battery or charging system if the clock resets. I would check the cables and connections to make sure everything is good.
Old Aug 7, 2013 | 7:41 PM
Tfriend's Avatar
I would check your cables and also have your alternator checked. Oriellys will check the alternator for free. It sounds like a loose connection, but could be also caused by the alternator not charging your battery like it should. Just a thought.
Old Aug 20, 2013 | 5:27 PM
KennyL's Avatar
Definately check for oxidized battery cable connections !!!!!
robuga
Apr 11, 2014 9:08 PM
Kryten98371
Apr 6, 2014 11:43 PM
beaver2low
Nov 24, 2013 11:56 PM
missouriboy1
Jul 25, 2013 4:44 PM
