2000 K2500 4x4bearing assembly & rotor to 1996 Suburban K2500 4x4
Old Feb 24, 2010 | 2:38 PM
jrsavoie's Avatar
Default 2000 K2500 4x4bearing assembly & rotor to 1996 Suburban K2500 4x4
I have a year 2000 bearing assembly. The bolt pattern is the same as the 96 but the rotor goes on the outside like it should.
I do not have the rotor to compare to the 96. If it was deep enough so that the faces of the rotor were in the same plane as the 96 OEM rotors And they were the same outside diameter I could swap the whole assemblies.
Does anybody know if this could be a swap or if there is a different swap option that would work and end up with removable rotors without pulling the whole bearing assembly?
w4audi
Aug 2, 2013 10:01 PM
kevbolacy
Feb 20, 2013 1:20 PM
tooNz213
Jul 19, 2010 1:26 PM
jrsavoie
Apr 15, 2010 10:58 AM
