2000 leaks in drivers floor board
Old Mar 28, 2005 | 9:10 PM
skidplate's Avatar
Default 2000 leaks in drivers floor board
my '00 1500 z71 leaks in the drivers floor board. i have looked all around the door and the seal looks good. oh by the way it is an extended cab . i would really appreciate it if anyone could tell me where else to look.
Old Dec 12, 2005 | 2:20 AM
Silveradotowpro's Avatar
I would be willing to bet you noticed water on the floor during the summer right? I have seen several of these trucks with condencer lines sweating into the cab. I do not know of a cure as of yet. I tested mine by putting towels under the floor mats to see how much moisture was occuring. Then tested again with no AC running...No leaks without the AC on...Let me know what your situation is. Maybe we can cure it together..
Old Jun 16, 2006 | 11:01 PM
jjohn82's Avatar
Default RE: 2000 leaks in drivers floor board
I just started having this problem also. I bought a 2000 in November. The former owner, a friend did not have the problem. I also just replaced the heater core. What causes this, and how do you fix it?
Old Jun 19, 2006 | 12:38 AM
viperjuice's Avatar
well, same as the other guy on this forum. make sure that you have that little black rubber tube sicking out through the firewall. cause if you don't that means that you pinched it during the instalation of the heater core box. the tube is attached to the box and you have to put it in the hole of the fire wall. it lets the condensation drain out
[IMG]local://upfiles/1535/A94D7E162E3C4CCFBAF533B891DFC3CA.jpg[/IMG]
[IMG]local://upfiles/1535/203477B748594CBC817FA1D3CC473165.jpg[/IMG]
[IMG]local://upfiles/1535/B8D140FB1A314166942BB9ADBD0DFA3C.jpg[/IMG]
[IMG]local://upfiles/1535/6456B585C3584E499500C5D09EAF8659.jpg[/IMG]
Old Jun 19, 2006 | 1:10 AM
jjohn82's Avatar
Thanks. That is exactly what it was. The hose was pinched. I knew it was something simple, I just didn't recall seeing a drain hose/plug during removal.
raweggfarts
Oct 21, 2014 7:55 AM
maxxmusle
Sep 6, 2008 5:50 PM
tweba99
Sep 8, 2007 8:14 PM
firemediceric
Jan 6, 2007 3:18 PM
