2000 Silverado Steering Headache
Old Oct 7, 2011 | 10:39 AM
Duck3241's Avatar
Default 2000 Silverado Steering Headache
I have an 00 Silverado ext. cab 4x4 with 5.3. I started out with leaking/stiff power steering, and there was some play in the steering wheel. I replaced the pitman/idler arms, the p.s. pump (twice), the p.s. gear box, greased all the front end fittings, adjusted the preload on the gear box, put new belts and a tensioner on. The play is all gone but the steering is still stiff (not a littlte stiff, a lotta stiff). If no one can help me figure out what is wrong with this thing will one of you shoot me please?! btw I do have p.s. assist at higher rpms.
Old Oct 7, 2011 | 11:26 AM
EinST's Avatar
You have "p.s. assist at higher rpms." It sounds like insufficient fluid pressure. If you have hydro-boost, maybe that's where the pressure is bled. Why did you replace the power steering pump twice? Did they gradually degrade?
Old Oct 7, 2011 | 3:08 PM
Duck3241's Avatar
I dont have hydro boost, but I have a feeling that I am loosing pressure somewhere too. I just found that if you turn the wheels with the front off the ground you hear a squirting noise like there is a hole some where. I replaced the pump twice because I thought I got a bad pump
liz109
Jul 3, 2010 5:18 PM
sneaky344
Oct 27, 2009 3:00 PM
FrankAlvarez1150
Aug 28, 2009 12:47 PM
aveo
Sonic (Aveo)
Jun 16, 2009 8:57 PM
boomer3
Mar 3, 2009 4:53 PM
