Notices
2000 Silverado turns over but won't start?
Old June 15th, 2010, 5:59 PM
ChevyMan333's Avatar
Default 2000 Silverado turns over but won't start?
The truck died while driving.
Fuel pump is good.
Spark plugs are firing.
Distributor cap is fine.
Even with gas poured into the throttle body it still won't start.
Even with the pedal to the floor it won't start.
Thought I might have jumped time, but it still turns over correctly.
Any ideas?
Old June 15th, 2010, 7:45 PM
maxxman04's Avatar
fuses? is fuel actually gettin in the cylinders? were all the gauges reading correctly before shut down?
Old June 15th, 2010, 8:26 PM
Professional Mechanic
MDTAHOE's Avatar
How do you know the pump is good?
Old June 15th, 2010, 9:12 PM
Checked fuses , i can feel fuel running through the fuel line by the throttle body , im not sure about guages reading right but i know my speakers got staticy right before it died . could it of jumped time?
Thanks for all your comments
Old June 16th, 2010, 6:42 AM
MDTAHOE's Avatar
That is no test for the fuel pump. It could have less than 10psi.
Old June 16th, 2010, 9:32 PM
well i changed the fuel pump today and new spark plugs ,distributor cap and rotor and i changed the crank sensor still nothing just turns over and over
Old June 16th, 2010, 11:33 PM
s34n's Avatar
have you checked out your battery or starter?
Old June 17th, 2010, 8:36 AM
ffmed6134's Avatar
strange, sounds like it is an ecm issue, I had this issue on mine and thank god mine was still under warranty - happened twice and didnt pay crap for it
Old June 17th, 2010, 8:27 PM
Well guys after trying everything I changed the cam positioning sensor and she started up perfect she has ran every since thanks for all your help
Old August 10th, 2010, 12:31 AM
Banned
Andrew123's Avatar
In 1997 Chevy pickup, fuel relay burnt around one prong, very hot, fuel pump won't run. I can change relay the pump will run again. Or any other solution?
Quick Reply: 2000 Silverado turns over but won't start?
