2000 Z71 Power window switch
Drivers window will go down but not up. I bypassed and put window up at motor. Do I need to order just the drivers switch or the hole electrical board which contains both window switchs and door locks?
RE: 2000 Z71 Power window switch
I have already replaced the regulator and rails (my cable snapped on the stock setup) but now it seems I have a problem in the connection. It seems to be either the switch or the wiring harness plug that isn't making a good connection. I had this problem before and wiggling the wires seemed to do the trick. No such luck this time....
I will have to find out which wires to "jump" to manually raise the window up. If that doesn't work then my ebay replacement regulator only lasted a week.
davbell22602
March 10th, 2010 8:36 PM
ASilver76
August 7th, 2008 2:36 PM
