2000 Z71 Power window switch
Old Aug 14, 2006 | 1:17 PM
3cylinder's Avatar
Default 2000 Z71 Power window switch
Drivers window will go down but not up. I bypassed and put window up at motor. Do I need to order just the drivers switch or the hole electrical board which contains both window switchs and door locks?
Old Aug 15, 2006 | 2:45 AM
NCHEVYHEVN's Avatar
Default RE: 2000 Z71 Power window switch
It's whatever the peice comes as. I beleive it comes as one big peice with all the switches but I'm not positive.
Old Sep 1, 2006 | 2:19 PM
Mammalian04's Avatar
I have the same issue. What did you end up doing?
Old Sep 1, 2006 | 3:03 PM
uncle bill's Avatar
"96 Camaro Z-28 23K miles. I had to replace both window motors in less than 20,000 miles. Hope Yours is a better design.
Old Sep 3, 2006 | 7:21 AM
I have already replaced the regulator and rails (my cable snapped on the stock setup) but now it seems I have a problem in the connection. It seems to be either the switch or the wiring harness plug that isn't making a good connection. I had this problem before and wiggling the wires seemed to do the trick. No such luck this time....
I will have to find out which wires to "jump" to manually raise the window up. If that doesn't work then my ebay replacement regulator only lasted a week.
justin69
Feb 28, 2015 2:54 PM
davbell22602
Mar 10, 2010 8:36 PM
ASilver76
Aug 7, 2008 2:36 PM
heavymetl420
Astro
Mar 23, 2008 9:17 PM
