2001 chevy 5.3 vortec over flowing reservoir and getting hot.
![Angry](https://chevroletforum.com/forum/images/icons/icon8.gif)
Hi, I'm new to this site and really need some help with my truck. I have a 2001 ex-eab short bed chevy with a 5.3 vortec. It was over flowing reservoir and then got hot. I have put a new radiator on it new water pump and thermostat purged all air out of system many times and checked the thermostat many times checked compression and it had 190 psi on all cylinders. So I thought well it can't be a bad head gasket cause such good compression so I thought it had to be a cracked head pulled the heads had them checked and they checked good for pressure test. So now I'm lost I've worked on alot of things and have never been this stumped I can usually figure it out but this one really gets to me so any helpful input would be awesome. Thanks for your insight in advance guys.
You could drive the truck about 2 miles off cold start and it would get hot and go into reduced power mode.
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
If the problem doesn't happen just sitting there idling and only happens when the engine is under a load try checking the clutch fan. make sure there is sufficient drag when you try to spin it. It should move very much at all. If it seems loose put a new on it or change over to a solid fan assembly. You may not be getting enough air cooling through the radiator also check for anything that would restrict the air flow. Make sure the shroud assembly is in place. Good luck...
Ronin7709
July 17th, 2013 12:36 PM
thisnthat
November 20th, 2012 11:36 AM
Chevrolet Forum News
October 1st, 2012 8:38 AM
ronks
March 23rd, 2007 5:01 PM
