2001 Chevy silverado 4l60e tranny help!!!
i am in the middle of taking out my transmisson in a 2001 4x4 chevy, and i cant get to the top bolts out im not even sure how many there are yet... is there any trick to get them? I cant even with the rear trans mount out and trying to lower it down it wont drop but a 1/2 inch from where it was. Can anyone at least tell me how many bolts or nuts there are.
2. 2 bolts.
The trick? You need a 3/8" or 1/2" drive 30" extension with a swivel U-joint socket on the end to get it on there from an angle. Then you hit it with your air ratchet or impact gun and zzzzp it comes straight out.
To put them in? Stuff a little wad of paper in the socket to secure the bolt and then line it up by hand in the hole and give it a few turns to keep it stuck in the socket nicely. Then when its in there nicely, hit it with the ratchet or gun to lock it down.
Of course you took out the transfer case FIRST right?
yes transfers out already.... so there for sure isnt a top bolt right dead center?... i will have to get back under there and look to see if i can see them from behind the tranny i know thats how i got out the two upper ones on the sides...on older trucks ive been able to drop the tranny down some and get right to them this ones not working like that lol
donbrearley
June 26th, 2013 10:26 AM
abqgolfer
August 27th, 2011 11:30 PM
a_r_fowler
December 4th, 2007 11:23 AM
