2001 HD2500 Brake Pad Replacement
Is it possible to replace the brake pads (and shoes - don't know if the truck has discs on the rear) in my driveway or are special tools, etc. required? Also, do the rotors have to be turned everytime?
I will say yes it is not to difficult. I have a 02 ,2500 HD and have done it without any problems. My truck has discs on the rear. You will need some good sturdy jack stands and a strong arm with 1/2 inch breaker bar with a good socket. The bolts holding the calipers on (2 on each caliper) have locktite on them and theyer a B#### to get loose. Be sure to use it after installing them. You probably won't have to turn the rotors if the pads metal parts have not been dragging, but you should have them checked with a micrometer to be sure. Are you planning to do both front and rear? They are similar unless you have drums on the rear. Hope this helps.
melat70
melat70
returnofsid
August 10th, 2014 1:23 PM
mctkmt
November 2nd, 2011 7:43 AM
negozio@verizon.net
September 26th, 2009 3:42 PM
DeHartShadow
September 9th, 2009 9:17 AM
pickeral
October 20th, 2007 9:50 PM
