2001 Seirra 1500 SL draw
Hey guys/gals, new to the forum, got a problem with my 2001 GMC Seirra 1500 SL. The unit was killing the battery after two days of not driving, performed a draw test using a test light, found a minifuse under the hood that stopped the draw when pulled. It was a 15 amp fuse labeled RADIO. When i started the unit up with no fuse the tach, speedo, odometer, fuel gauge, message center and radio do not work. The fuel gauge has been sensing erratically, I was told this is a normal problem as the contacts get gummed up. Also the radio clock had been jumping around when i shut the truck down (not always back to 12:00), so i disconnected the radio completely, still drawing amps when not running, so that should eliminate the radio from being the source of the draw. Just wondering if anyone has any ideas on how to find this draw in that circuit. Im not to well versed in electrical diagnosis, but willing to try it out. Thank you for your time.
Curtis.
Curtis.
![Cool](https://chevroletforum.com/forum/images/icons/icon6.gif)
Do a thread search here in the Silverado section. This is a common problem, and you have to have the PCM reprogrammed to eliminate it.
I'm unsure of the recall-warranty status in this case.
Professional Mechanic
You can not properly test for a draw with a test light. Almost every car will light the test light. You need to use a DVOM set on amperage. Disconnect the negative cable, connect 1 lead to the battery and the other to the battery cable. You need to be around 25 ma give or take a little. You must wait until all the modules time out for the correct reading, usually with in a min.
Ron Malinowski
May 29th, 2014 11:03 PM
IamLegend
February 2nd, 2012 7:36 PM
IamLegend
January 28th, 2011 6:26 PM
justin.chamberlain
November 3rd, 2007 6:39 AM
