2001 Silverado 1500-clogged fuel cannister?
Old Oct 19, 2011 | 9:44 AM
blackdawg1's Avatar
Default 2001 Silverado 1500-clogged fuel cannister?
My 2001 Silverado 1500 (V8) Z-7l (4X4) has intermittent problems with all the dash lights coming on, (check engine, ABS, Brake) as well as heat/ac working then stopping. If the truck is full of fuel, everything works..was told it could be a "clogged fuel canister" and that it wasn't serious. Checked fuses, all seem ok any ideas? I'd appreciate any advice.
Old Oct 19, 2011 | 7:30 PM
EinST's Avatar
Welcome to the forum. You obviously have an electrical problem but I fail to see the "clogged fuel canister" angle. About the only thing that I can think of is that the EVAP tests don't run when the fuel tank is full but so what? Do the gauges sweep when the warning lights come on like when you first turn the key to on? If so, you may have a power supply problem with the I/P cluster.
Old Oct 20, 2011 | 7:37 AM
blackdawg1's Avatar
Thank you, I appreciate your time.
Fly_Like-a-G20
11
Oct 16, 2014 8:30 PM
domano 68
Feb 7, 2013 6:51 PM
doctrdoo
16
Nov 28, 2012 11:21 AM
mstrano
Camaro
Jun 11, 2012 4:33 PM
johnny
Jun 30, 2006 2:26 PM
