2001 Silverado A/C & Heat full hot or full cold. No blending
Old Jun 27, 2012 | 1:57 AM
Stephen Doak's Avatar
Default 2001 Silverado A/C & Heat full hot or full cold. No blending
The truck has manual single control heat and air. I've recently replaced the actuator for the temperature control. The door moved easily with my fingers before I installed the actuator. I made sure that all controls were on cold before I attached the new actuator. I can get full cold or full hot but nothing in between. In order for the a/c to be on, the switch has to be on the red side and for heat the switch has to be on the blue side. I've tried every recalibration method I can find. Any one know what else I can try?
Old Jun 27, 2012 | 12:00 PM
I would guess that the actuator was not properly installed since you say that for the A/C the switch has to be on the red side and blue for heat. This is backwards.
Old Jun 27, 2012 | 11:20 PM
I've reset the switch, pulled the actuator, manually reset the blend door and disconnected the battery several times following the installation and calibration instructions. Still no joy. Is there a way I can reset, after reinstalling the actuator and get the proper temp setting and get variable temp air?
Old Jun 28, 2012 | 10:55 AM
Did you put power to the actuator before installing it?
Old Jun 29, 2012 | 5:41 PM
Nope. All instructions I could find said to install it first, then plug it in with either the batter negative cable unhooked or all the hvac fuses pulled.
Old Jun 29, 2012 | 7:21 PM
wondering if the blend door actuator has to be calibrated after replacement? Newer model years do.
Old Feb 2, 2013 | 6:48 PM
stemwall's Avatar
please help... i have the same problem how did you fix it... thanks ken
ntheath
Aug 28, 2020 3:36 PM
ericnottelin
Jun 29, 2010 7:43 PM
phatgi
Apr 28, 2009 12:14 AM
clayman
Apr 19, 2009 7:55 PM
eric4947
Jan 27, 2009 9:12 PM
