2002 2wd front end lift question???
Hey all,
in my possession I have a 2" coil spacer leveling kit for my truck. After It has been installed my truck will be level. I want to go further and add another 2-3" without having to mess with spindles, control arms, etc, etc. If i can accomplish this ill add blocks and u-bolts in the rear to gain a level 2-3" lift all around.
the truck is a 2WD 2002 silverado 1500. How can I add a couple more inches up front after the leveling kit is in place without a full suspension lift kit(budget issues......)
Spindles are cheap, those would be the best bet honestly...without goin either spindles or full suspension lift that leaves you with a body lift.
What I'd do, is do a 3" spindle lift, 3" block out back then add a 1.5" body lift on top of it. All in all about 400 if you can find a deal on the spindles, if not then about 500(200 for body lift and 300 for spindle lift). Blocks are cheap so I didn't include those
Allans454
November 20th, 2012 5:22 AM
Rlock4227
February 19th, 2012 11:26 AM
guitarhero
January 5th, 2008 11:44 PM
